Denyo 280 welder
发表于 2021-8-31 23:06:47 | 显示全部楼层 |阅读模式
I have a SA-200 Lincoln and a 300 amp Lincoln shop welder , both weld good. I bought a used Diesel Denyo 280 welder because I wonted a Diesel machine and a generator, I smokes and that is fixable but the ark is not stable and is no where as smooth as the SA-200. It sticks and frys and generally just makes me wont to find a new home for it. Has any one welded with one of these machines. It is suppose to be open Delta wound.   If it is suppose to be smooth then I can have the thing repaired and I will rebuild the engine. If not I will sell it and use the money to buy a good diesel generator. thanks for any help JimK
GMT+8, 2025-12-28 08:10 , Processed in 0.113401 second(s), 18 queries .
