查看: 13|回复: 0
This Was Supposed To Be Quick And E-Z....
发表于 2021-8-31 23:06:45 | 显示全部楼层 |阅读模式
But that is not the case..Another busted journal on a press roller..Seems easy enough..Drill..Bore..Install new end...While heating discover crack around the head itself..Back in the machine and drill some more..Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:And drill some more..Time for the boring bar..Time for a bigger boring bar..End of roller done..Time for another new shaft..Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:New heads...004 shrink and while you are at it face off where the weld goes..Grind the backside where the weld goes..Heat and shrink on shaft..Let cool and do the rear head same way..I only shrink heads to shafts when building/repairing press rollers..Get the positioner out again..One more time.....zap!Last edited by zapster; 01-17-2013 at 05:13 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:First pass..Second pass..This is only done on the outside that shows..Welds for the inside..Tomorrow it's turn..Shrink..Weld..Finish.Until then..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ok question what is the lathe dog used for in this instance is it for depth stop?350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I'm guessing to stop the bit from turning??  Another excellent post Zap !!Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by umahunterOk question what is the lathe dog used for in this instance is it for depth stop?
Reply:K I get it thanks350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Beautiful !!!!!!!!!!
Reply:VERY nice welds and machining.  An artist at work.....
Reply:Some fine quality work there bud! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Where's the dime???"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Mick120Hey Zap, those welds on the steady look a bit porous.......Then again, they've probably been like that for 40 years so, if it ain't broke, don't fix it.....
Reply:Originally Posted by Stick-manWhere's the dime???
Reply:Holy Crap...that's some scary welding. I'm gonna go jump off a bridge....can't handle seeing this stuff anymore...
Reply:Originally Posted by SMC WeldcraftHoly Crap...that's some scary welding. I'm gonna go jump off a bridge....can't handle seeing this stuff anymore...
Reply:Looks good, you post a lot of roller work, is that the bulk of your work?PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Originally Posted by castweldLooks good, you post a lot of roller work, is that the bulk of your work?Peter
Reply:ZAP my positioner is the same make and looks like the same size as yours, but a little newer so to speak, do you worry about overloading it weight wise at all. I don't, I know the specs on it but it never even burps for help, so i'll just keep pushing it. Whats your opinion bud?I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by zapsterWhere is your glasses?...zap!
Reply:Great job..need a new dime, that one is not as shinny as your work....
Reply:Originally Posted by weldermikeZAP my positioner is the same make and looks like the same size as yours, but a little newer so to speak, do you worry about overloading it weight wise at all. I don't, I know the specs on it but it never even burps for help, so i'll just keep pushing it. Whats your opinion bud?
Reply:Originally Posted by a1998z3Great job..need a new dime, that one is not as shinny as your work....
Reply:Looking good Zap!Buy American, or don't whine when you end up on the bread line.
Reply:Looks good zap!! I'm on my phone and really couldn't tell, but are you using brazed carbide tooling? If so how do you like it compared to hss or inserts?Thanks,ChrisOriginally Posted by Tamper84Looks good zap!! I'm on my phone and really couldn't tell, but are you using brazed carbide tooling? If so how do you like it compared to hss or inserts?Thanks,Chris
Reply:OK as we continue..Take the head assy and put it back in the machine for turning the OD for shrink fit into the roller..  .004 this time..Then face the front off and then put the radius tool to work..Much easier to do all this now rather when the roller is assembled..Before heating/inserting clean out the chips!I use a magnet taped to a aluminum rod for this..Heat tube..Install.Next.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Now weld in the head..Done sideways..Now put the repair end back in the chuck..Indicate the ROLLER in to zero..Turn the weld off and put a new steady rest spot on the shaft..Now set the steady rest up on the new spot..Next.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Zap,I don't know what the hell you're doing half the time, but I sure enjoy watching it. Keep it up!
Reply:Now flip the assy around and insert brass ring in the chuck so you don't mark up the finished journal on the other end..Slide the steady rest to the other end of the machine..This makes centering the shaft so easy because the rest is already set up dead center..Face to length..Rough it out..Let cool and finish Monday..I had to use a big piece to do this because we did not have any 4140 to use and this piece was salvaged from another smash and crash job..And now it's off to the dentist....zap! Attached ImagesI am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by joshuabardwellZap,I don't know what the hell you're doing half the time, but I sure enjoy watching it. Keep it up!
Reply:whyzit gotta be a '66?
Reply:Originally Posted by weldbeadwhyzit gotta be a '66?
Reply:All I say to myself when I look at your work is I have a lot to learn.
Reply:Originally Posted by zapsterNow set the steady rest up on the new spot..Next.....zap!
Reply:Originally Posted by zapsterI don't know what I am doing half the time either.....zap!
Reply:Originally Posted by sanddan52Is that emory paper in this picture? If so, why do you use that under the steady rest?Thanks for sharing your work!
Reply:Originally Posted by zapsterIt got over heated over time while sitting next to hot welds..If I find another ' 66 I will trade it out....zap!
Reply:Originally Posted by MondoBust open an old thermostat and extract the blob of mercury from the glass bulb, rub the mercury on the dime then polish off with soft rag.  The dime will shine, shine, shine!Save the little blob of mercury in a tightly capped plastic bottle for another day.Don't be afraid of it, it isn't nearly as toxic as it is made out to be.  Just don't heat it up and inhale the vapors.- Mondo
Reply:You get all the good jobs...Nice work ZapBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by zapsterMaybe I should try Mrs zap's silver polish.....zap!
Reply:try rubbing compound works great on plastic headlights too ( needs waxing after to seal though) also is great on kitchen sinks and pots and lots of other stuff.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:I don't know jack about lathes. I want to. I saw that weld on what I think is called the steady rest. I was wondering a few things....why did you not fix that? Is that safe? I am scared of spinning heavy metal. I would want everything to make me feel warm and fuzzy. Also, so does the material just spin inside the steady rest on the brass tips? how long do those tips last? are they spring loaded on the inside? I know, I could google it, right? sorry.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:When you're good, you're good.  Always a joy to see your stuff Zap!JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:Originally Posted by Joker11I don't know jack about lathes. I want to. I saw that weld on what I think is called the steady rest. I was wondering a few things....why did you not fix that? Is that safe? I am scared of spinning heavy metal. I would want everything to make me feel warm and fuzzy. Also, so does the material just spin inside the steady rest on the brass tips? how long do those tips last? are they spring loaded on the inside? I know, I could google it, right? sorry.
Reply:Here we have a homemade rest..Actually there are 2 of them for this machine also..The brass parts are made in house and I have tall ones and short ones and these rests that I can swap out as needed for different size shafts/rollers..They adjust just like the first one but use nuts and bolts for adjusting/locking in place..So now you know how they work!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I finally had to use my steady rest last week at work. Even after reading all of Zap's post and pics I forgot the bits of emery cloth. Luckily all I was doing was center drilling a long piece of 2" aluminum bar for the live center so I could turn it down to 1.5", so the marring made no difference.  Oh, and Zap, I realize in your shop (like most) time is money. But my boss would blow a gasket over a floor littered with shavings. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:you need to clean up, shops a messtackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:You can come over anytime and help me clean..Even after a month you would get nowhere.And trust me on this..I have the cleanest area in the place....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:God I love looking at your welds!!!!!!!!!!!!!Pus you have a PMDave ReberWadsworth Ohio
GMT+8, 2025-12-28 08:29 , Processed in 0.072747 second(s), 18 queries .
