Has anyone made there own radius cutter?
发表于 2021-8-31 23:06:43 | 显示全部楼层 |阅读模式
Back at my old job they had a few homemade radius cutters that go on the torch I'm not sure how to start making one? Does anyone have there own homemade radius cutter to cut circles
Reply:Originally Posted by 98rampowerBack at my old job they had a few homemade radius cutters that go on the torch I'm not sure how to start making one? Does anyone have there own homemade radius cutter to cut circles
Reply:Ya somethin like that but it wasn't magnetic it just held on to the torch.
Reply:Looks nice Jerry!! Many ways for adjustments..thanx for sharingMiller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:I made one for one cut. Just took a piece of bar stock, measured how far I wanted for a hole drilled a hole for the torch of the plasma cutter to fit. Then a hole at the other end and a screw or bolt to secure it to the base metal.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Here's the one  I made and use every week. No need to complicate matters, it works perfect!  Attached ImagesI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeHere's the one  I made and use every week. No need to complicate matters, it works perfect!
Reply:That's a nice little setup there weldermike I might just do that but my tubes on my torch ain't that long. Look simple an easy to adjust
Reply:Do a search as there is a thread on them with lots of pictures.
Reply:I freehand it too ..but I am also going to make one of these someday...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by 7A749Gerry, that is a sweet circle cutter!!!
Reply:Finally had time to make it cuts good Attached Images
Reply:Almost cuts 3' circles short about 2" Attached Images
Reply:One one i use is similar to this bought from Princess Auto (one pictured is for Victor Style)98RamPower i really dislike using that style of torch, Kills my hand.Love these style though Harris 85 with 72-3 current unit is this but its knobs SUCK (top one) lower unit is a Harris with 36-2 its nice but tips are twice the price of the 6290 tips and way harder to get localy
Reply:Yea I can see what ur sayin that it hurts ur hands back when I was usin the one at work I tied zipp ties to it so i wouldn't have to grab the torch an the bar but I put a little bend on it so its in a bind so all I'm grabbing is the torch. I don't like those magnetic ones to much but urs don't look to bad
Reply:I have these I make for plasma cutters.  The magnet can come off & a 8/32 screw dropped into a small hole drilled at the center of the circle.  The set screws grasp the insulator & it rotates so you don't have to change the grip of the torch head.It has a double shielded ball bearing to support the torch tip away from the metal. Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Oh GREAT! Something else I have to make! LOLVery nice guys. I did make a quick and dirty one a while back to cut some 5" circles in aluminum, worked great but I lost track of it.
Reply:The holes are drilled 1 inch apart.  One pin is installed 1" away from the holes.  This gets you circles with radius of 1", 2", 3" up to 6" depending on which hole you stick the torch through.Another pin is installed 1/2" away from the holes.  This gets you circles with radius of 1/2", 1-1/2", 2-1/2" etcAnother pin is installed 3/4" away from the holes.  This gets you circles with radius of 3/4", 1-3/4", 2-3/4", etc.Another pin is installed 1-1/4" away from the holes.  This gets you circles with radius of 1-1/4", 2-1/4", 3-1/4", etc.When cutting, use a punch to mark a divot for the center.  Place the desired pin in the center divot.  Place the torch in the desired hole. Hold other end up a little so the other pin will clear.  Then cut and rotate.One tool hits all these sizes with no adjustments, no measuring, and the tool fits in your shirt pocket!Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Originally Posted by AndyAThe holes are drilled 1 inch apart.  One pin is installed 1" away from the holes.  This gets you circles with radius of 1", 2", 3" up to 6" depending on which hole you stick the torch through.Another pin is installed 1/2" away from the holes.  This gets you circles with radius of 1/2", 1-1/2", 2-1/2" etcAnother pin is installed 3/4" away from the holes.  This gets you circles with radius of 3/4", 1-3/4", 2-3/4", etc.Another pin is installed 1-1/4" away from the holes.  This gets you circles with radius of 1-1/4", 2-1/4", 3-1/4", etc.When cutting, use a punch to mark a divot for the center.  Place the desired pin in the center divot.  Place the torch in the desired hole. Hold other end up a little so the other pin will clear.  Then cut and rotate.One tool hits all these sizes with no adjustments, no measuring, and the tool fits in your shirt pocket!
Reply:wow that last one is so simple its amazing!
Reply:^ agreed
Reply:Here is the old thread http://weldingweb.com/vbb/showthread.php...=circle+cutterDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Here's a few pics of my cutter.....made for my plasma rig. I brought the nozzle to my local bearing distributer and they sized the bearing just perfect. This thing cuts some sweet circles. Attached Images
Reply:Originally Posted by SMC WeldcraftHere's a few pics of my cutter.....made for my plasma rig. I brought the nozzle to my local bearing distributer and they sized the bearing just perfect. This thing cuts some sweet circles.
Reply:Here's one I made just about 100-years ago. I use it a lot with a rotating table I made also. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400The pic posted by Gerry1964 is mine. Here it is in action cutting 2.25" plate.[ame]http://www.youtube.com/watch?v=hUzXEn7YwVw[/ame] Attached ImagesDarwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
GMT+8, 2025-12-28 09:51 , Processed in 0.112656 second(s), 18 queries .
