Save The Snap Ring Groove...PLEASE??
发表于 2021-8-31 23:06:39 | 显示全部楼层 |阅读模式
OK you get what you ask for..Roller with worn out bearing surface right next to a snap ring groove..Like usual..No biggie..035 70S-2 Filler..Welder on "Stun"...Finish Dia    1.181+.0004  -.0000I gave it +.0003Pics from start to end..Let me see you do THAT with a stick or mig machine.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Why bother saving it.  Welding the groove shut and re-cutting is not going affect the time/cost much.  Was it a customer request or your choice?My name's not Jim....
Reply:Originally Posted by BoostinjdmWhy bother saving it.  Welding the groove shut and re-cutting is not going affect the time/cost much.
Reply:Originally Posted by BoostinjdmWhy bother saving it.  Welding the groove shut and re-cutting is not going affect the time/cost much.  Was it a customer request or your choice?
Reply:very nice build up on the bearing surface and machining. i can't wait to start that tig class.i.u.o.e. # 15queens, ny and sunny fla
Reply:Looks damn good, Zap!! I see your reasoning on the groove.                                       MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:zap, what is the difference between STUN and KILL on the 330! nice job as usual by the way.
Reply:Originally Posted by dbl612zap, what is the difference between STUN and KILL on the 330! nice job as usual by the way.
Reply:Groovy.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:They are nailing you for .0004"  Have they not heard of a bearing heater?
Reply:Originally Posted by zapsterGetting the snap ring tooling out..Setting up a indicator..Measuring the depth..All  = TIME.I take this route so nobody can say.."It's too deep""It's too close""It's too wide""it's not wide enough""It's too far away"..They get back what came in without all the slop in the bearing surface....zap!
Reply:Originally Posted by Dualiebut they can say you distorted it with the heat from welding.
Reply:Originally Posted by 76GMC1500They are nailing you for .0004"  Have they not heard of a bearing heater?
Reply:Whew, thank god that pin hole turned out!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:There's that same dime again.  Don't change it or polish it to make it shiney as suggested in another thread.  It has a nice antique patina!Nice fix, as usual, too!- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by MondoThere's that same dime again.  Don't change it or polish it to make it shiney as suggested in another thread.  It has a nice antique patina!Nice fix, as usual, too!- Mondo
Reply:Very nice work as allways....how did you hold 0.0004" on a lathe...???
Reply:The print is probably supposed to say -0 +.0014 but... we all know how engineers can be.  I mean the bearing isn't even .0004 precise.
Reply:Originally Posted by ZZWELDVery nice work as allways....how did you hold 0.0004" on a lathe...???
GMT+8, 2025-12-28 08:10 , Processed in 0.112134 second(s), 18 queries .
