testing oxy acetylene regulators
发表于 2021-8-31 23:06:38 | 显示全部楼层 |阅读模式
Just picked up a used torch set from a guy on craigslist. Came with a pair of victor 450/460 series regs. How can i test them to make sure they are working well? The models are Sr450d oxygen and sr460a acetylene.
Reply:Originally Posted by xavier23Just picked up a used torch set from a guy on craigslist. Came with a pair of victor 450/460 series regs. How can i test them to make sure they are working well? The models are Sr450d oxygen and sr460a acetylene.
Reply:Originally Posted by Gerry1964Connect them up to a bottle and fire away?  then just adjust until you can see the different ranges, other than that i don't really know
Reply:Originally Posted by xavier23Last thing i want to do is hook them up and shortly after become front page news.
Reply:Originally Posted by anickodeTest 'em outside.Your acetylene tank should only be open enough to allow gas flow, so you can shut it off quickly if something goes wrong.
Reply:I'm always leery of O2 regs with unknown history. If they look greasy and oily, I wouldn't hook them up, I'd spend the money to have them serviced. HP O2 and oil are a disaster waiting to happen. Normally this isn't a big issue if the regs are properly taken care of and on cylinders, but a reg tossed in an old tool box full of greasy oily tools isn't a good combination..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWI'm always leery of O2 regs with unknown history. If they look greasy and oily, I wouldn't hook them up, I'd spend the money to have them serviced. HP O2 and oil are a disaster waiting to happen. Normally this isn't a big issue if the regs are properly taken care of and on cylinders, but a reg tossed in an old tool box full of greasy oily tools isn't a good combination.
Reply:Originally Posted by xavier23I thought about doing that, but it worries me. These regulators haven't been exposed to pressure for about 10 years. I was thinking about taking them to the LWS, when i go to have the oxygen tank filled, and having them take a look. Last thing i want to do is hook them up and shortly after become front page news.
Reply:Originally Posted by Gerry1964I'd be more worried about the old hoses than the regulators if the hoses havn't been used for 10 years they would probably leak far more than the regulators.If i was you Buy some leak spray, and test them, the leak spray would bubble up if theres any leaks, But regulators in general are pretty hardy, If everythings tight they shouldn't leak cos they are old.Finally you haven't mentioned, but do you have flashback arrestors, If not you need to get some one for the Oxy, and one for the acetylene. (very Important!!!)
Reply:They go directly after the regulator and before the hose Sometimes if you have a really long Hose, people also put them at the end of the hose before the torch inlet
Reply:Don't stand in front of the oxygen regulator when you crack open the oxygen bottle valve! (This is always good advice.)
Reply:Originally Posted by Gerry1964They go directly after the regulator and before the hose Sometimes if you have a really long Hose, people also put them at the end of the hose before the torch inlet
Reply:Should i replace the oxygen tank pressure gauge, as the gauge stem is bent, and the graduated face is warped? If it does have to be replaced, can i install it myself?
Reply:Gauges are easily replacable.  When you replace the gauge, teflon the threads.  Also if the gauge stem is bent, make sure the threads are okay and that nothing else is damaged!  If your regulator doesn't have a flashback arrestor, install one.  At the torch end, check valves are all you need.Last edited by mb_welder; 08-22-2012 at 05:58 AM.
Reply:Originally Posted by mb_welderGauges are easily replacable.  When you replace the gauge, teflon the threads.  Also if the gauge stem is bent, make sure the threads are okay and that nothing else is damaged!  If your regulator doesn't have a flashback arrestor, install one.  At the torch end, check valves are all you need.
GMT+8, 2025-12-28 08:18 , Processed in 0.175888 second(s), 18 queries .
