What size is this acetylene tank?
发表于 2021-8-31 23:06:36 | 显示全部楼层 |阅读模式
I recently bought a used torch set via craigslist. Swapped the oxygen bottle today, turns out it 125 cu ft, yet i am unsure what size acetylene i have. The tank measures 39 inches high x 8.25 inches in diameter. Does anyone know what cubic foot volume this equates to? It also came with a victor 6-mfa rose bud, should i get a bigger tank to run this tip? Searching the web tells me it could be anywhere between 100 and 150 cubic feet, so no help there.
Reply:Info here...http://weldingweb.com/vbb/showthread.php?t=54419...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterInfo here...http://weldingweb.com/vbb/showthread.php?t=54419...zap!
Reply:Originally Posted by xavier23That's good information, but i was in search of something to tell me the exact dimensions of each tank size, rather than a rough chart. Something more to the effect of AxB is so and so cubic feet.
Reply:This should get you real close...http://tricowelding.com/cylinder_sizing.htmlLooks like 100 cf to me.
Reply:Originally Posted by DSWUnfortunately you won't find such an item. There are a number of companies making cylinders, and all are just a bit different. Also acetylene is stored in a porous material inside the cylinder and is dissolved in acetone. That means that unlike a "conventional" gas it's not as simple as a volume measurement.As far as other gasses like Argon, 75/25, O2 etc., unless you are working with metric cylinders that are done in liters, gas volumes are pressure related and the math is a bit "complex" for the average person. Total volume is based on cylinder size x rated pressure.I'll used my dive cylinders since I'm most familiar with working those numbers as examples.An 80cf 2400 psi cylinder is approximately the same physical size as a 100 cf 3500 psi  cylinder. A 2400 psi 104cf cylinder is much larger than the 3500 psi 100. An alum 100 cf cylinder is even larger, yet it holds 3500 psi because the cylinder walls are thicker. Physical dimensions of each size will also vary depending on who manufactured the cylinders, and sometimes they vary even from the same manufacturer, if the cylinders are a couple of years apart in age.From your description it sounds like you have a 75 cf acet cylinder. That's roughly the size my 2 are.
Reply:Originally Posted by ProChargerThis should get you real close...http://tricowelding.com/cylinder_sizing.htmlLooks like 100 cf to me.
Reply:Anyone who can confirm the 130 cu mark means 130 cubic feet? I would normally make the assumption but i don't want to overdraw this tank.
Reply:bump.
Reply:Airgas lists one 8" x 39" (with cap) at 145 CF. Air Products lists an 8" x 30" (without valve) at 130 CF.There is a WSL size that's 130 CF, supposedly 8.5" outside diameter - 33.5" tall, and a WS - 130 CF - 8.5" outside diameter - 35.5" tall"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumAirgas lists one 8" x 39" (with cap) at 145 CF. Air Products lists an 8" x 30" (without valve) at 130 CF.There is a WSL size that's 130 CF, supposedly 8.5" outside diameter - 33.5" tall, and a WS - 130 CF - 8.5" outside diameter - 35.5" tall
GMT+8, 2025-12-28 09:49 , Processed in 0.106367 second(s), 18 queries .
