120 v Welder
发表于 2021-8-31 23:06:36 | 显示全部楼层 |阅读模式
Hi everybody I need advice.I have a millermatic 130 that i use wiht 25/75 mix.When I weld my deposition seems to be to much.I lessened my wire speed still the same.I raised the voltage still the same.I weld and it looks like globes.When i weld with my Lincoln 180t 220 v. it dispereses the material so niceI was wondering if I could get some advice PleaseLakehunter
Reply:Only advise I an give is never to buy transformer 115volt migs. Only inverter 115 volts units will have the grunt to maintain as smooth an arc as your 220 volt mig.You will see lots of dual voltage units around, they work well, and they are all inverter power supply.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonOnly advise I an give is never to buy transformer 115volt migs. Only inverter 115 volts units will have the grunt to maintain as smooth an arc as your 220 volt mig.You will see lots of dual voltage units around, they work well, and they are all inverter power supply.
Reply:I gladly accept your advice.Would like to ask :is there a solid wire that melts easyier on this machine:MillerMatic 130CV.DC Welding Source/Wire Feederser.no.- kf799846
Reply:What diameter of wire are you running?Miller Dailarc HF 250 Hobart 140
Reply:Originally Posted by turkincorrect, the miller 211 is transformer based
GMT+8, 2025-12-28 09:53 , Processed in 0.106962 second(s), 18 queries .
