trying to brush up on my tig welding
发表于 2021-8-31 23:06:36 | 显示全部楼层 |阅读模式
due to being in the factory mig welding 12 hours a day for the last year or so i havnt been able to keep up with my tig practice. sdo basically im starting from the beginning unfortunatly my camera phone seems to have had better days but:syncrowave 200about 170 amps3/32" 2% thoriated tungsten15 cfm on the argonlet me know how much i suck lol
Reply:You need work on rythem but other than that..Go weld 2 pieces together now then we'll see.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Practice, practice, practice.Ian TannerKawasaki KX450 and many other fine tools
Reply:in a butt weld?
Reply:Try a "T"......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:the ones in the second pic are t's
Reply:Top pict you dipped the tungsten and then didn't stop and grind. I can tell from the "soot" that shows visibly at the top of the pict.As mentioned you need to work on your consistency from what I see in the picts. Overall they aren't bad for a beginner, but you need to work on the details now. Since I see what might be a tendency towards short 1-2" long sections that seem to be similar in the T picts, I'm guessing you are feeding about that much wire and then either stopping, repositioning, or readjusting to get more filler forward.If your issue is that you have used up all the filler available forward of your hand, you need to practice on sliding filler forward as you go continuously. I usually suggest students take a 1/2 piece of filler and "play" with it while they watch TV. Just work on moving the filler back and forth thru your feed hand one handed. The idea is to train your hand in those motions. You don't have to be welding to do this, and the distraction of watching tv helps so that you get used to doing this without concentrating on it. You have other things to concentrate on while welding than the motions of feeding filler..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by AnnLindelYou must have respect for them
Reply:i am having the same problem, since i am just learning, but mine looks worse. any tips on how to keep the rythem
Reply:Originally Posted by pasttimes8i am having the same problem, since i am just learning, but mine looks worse. any tips on how to keep the rythem
Reply:Make test runs, and be comfortable. And count in your head as you go. Like a metranone in your brain.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by shovelonUse bigger rod.
Reply:Originally Posted by soutthpawHere is a online supplier that has awesome pricing on aluminum TIG rod up to 3/16" https://weldingsupply.securesites.ne...:terms::PE#E01Just ordered 1/8, 5/32 and 3/16 myself.if anyone finds a online seller for small quantities of 1/4" aluminum Tig rod, please post up a link.  Thanks
Reply:More gaas flow, larger cup, more stick out, and/or a gas lens will give u plenty of stick outTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawif anyone finds a online seller for small quantities of 1/4" aluminum Tig rod, please post up a link.  Thanks
GMT+8, 2025-12-28 09:53 , Processed in 0.094692 second(s), 18 queries .
