Max 42 help
发表于 2021-8-31 16:58:36 | 显示全部楼层 |阅读模式
I have a Max42 that won't work. I understand the boards are no longer made. I tried to repair the PC12 board. There are only a few components on it. I still get no output (+12 volts) on it even using the exact parts. I unloaded the 12 volts to see if it were being loaded down.Has anyone troubleshoot this unit?  Switch in torch is working.
Reply:Originally Posted by GunslingerI have a Max42 that won't work. I understand the boards are no longer made. I tried to repair the PC12 board. There are only a few components on it. I still get no output (+12 volts) on it even using the exact parts. I unloaded the 12 volts to see if it were being loaded down.Has anyone troubleshoot this unit?  Switch in torch is working.
GMT+8, 2025-12-18 18:26 , Processed in 0.112852 second(s), 18 queries .
