AEAD 200LE welder/generator
发表于 2021-8-31 23:06:29 | 显示全部楼层 |阅读模式
I have no power to outlets,and need to know what might be the problem?
Reply:See your other thread on the topic.http://weldingweb.com/vbb/showthread.php...der&highlight=MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:i did, im not into all the testing, cuz i have no idea what im doing i thought it would be a change few parts and done,thx
Reply:im not into all the testing, cuz i have no idea what im doing i thought it would be a change few parts and done,thx
Reply:why wow, i dont know how to use the testers they talk bout
Reply:Originally Posted by Dirk Wiersmai did, im not into all the testing, cuz i have no idea what im doing i thought it would be a change few parts and done,thx
Reply:Originally Posted by Dirk Wiersmawhy wow, i dont know how to use the testers they talk bout
Reply:yeah ,but if you have never run one, then,you arent going to be able to test things
Reply:If you can't test with a multimeter and at least try to follow a schematic then you've not got much chance of fixing it. Well you might be able to fix it but it could cost a fortune changing parts till you find the one that's out. There's just to many things that can be wrong.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Originally Posted by Dirk Wiersmayeah ,but if you have never run one, then,you arent going to be able to test things
Reply:If you have any questions about how to test certain components or using the test equipment, there is a ton of related videos on YouTube you could watch and increase your knowledge in the process.As irish fixit indicated, pokin'-n-hopin' by just changing parts is NOT the way to go.  It can get very expensive and frustrating and you may wind up investing way more than a machine is worth.  Just as bad or worse, after replacing everything else you might find a major component that is no longer available is to blame and you're left with an oversized doorstop.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:ok, got it fixed ,thx to all for the help ,was the sr2 rectifier
GMT+8, 2025-12-28 08:10 , Processed in 0.118414 second(s), 18 queries .
