kelly
发表于 2021-8-31 23:06:28 | 显示全部楼层 |阅读模式
Just curious if anyone has noticed a drop in voltage after rigging up cable reels? Thanks
Reply:Rigging up=adding reel + wire, or just the reel? Adding wire increases circuit resistance, especially if it's not big enough. That can reduce voltage. If you're losing power somewhere, the area losing the power should get hot after a bit of welding.
Reply:Just added reels. I checked all connections to see if any were hot. All good.
GMT+8, 2025-12-28 08:11 , Processed in 0.072268 second(s), 18 queries .
