circle cuter for the torch
发表于 2021-8-31 23:06:26 | 显示全部楼层 |阅读模式
With this guide you don't have to walk around your work like some home made guides. Also it has no wheels to stop and skid on a small piece of slag. Just use a center punch to mark the center of the hole to be cut, put the guide pin in the center and with one hand on the torch and the other on the guide start your burn and go. It takes a little practice to do but once you have it you will like it. Attached Images
Reply:That's pretty slick. Little intense for my limited fab skills. Worth a try some day. Looks good tho.
Reply:Here is a real one, every good fitter needs one in his box, even if you only use it once a year...  Attached Images
Reply:digr, again I can see no pics and I'm very curious.
Reply:i use a 1/0 lug with a 16 p nail bent like yours attached to the torch , without the rest of setup like yours.yours is not bad at all . mine was a fast remedy in a situation that worked
GMT+8, 2025-12-28 08:11 , Processed in 0.096485 second(s), 18 queries .
