Iron Worker
发表于 2021-8-31 23:06:25 | 显示全部楼层 |阅读模式
Greetings: We are in the process of purchasing an iron worker. We've narrowed the choices down to  a Brobo  and a Scotchman. Both are appox. 90ton. Anyone have any experience with either of these machines? Already have a Brobo cold saw, excellent machine. Don't have any experience with an IW.Thanks.
Reply:Sctochmans tend to be cheaper.  I don't like them myself.  If you ae insanely rich you buy a Peddinghaus from Germany.  I really like the Pirahna brand.  It is a good compromise.  The hold downs are the best using UHMW plastic block that is indestructable and hold close to the shear blade.  Their punch stripper is also well designed.  I can't seem to find a Pirahna websitehttp://www.peddinghaus.com/Peddingha...teelworker.htm
GMT+8, 2025-12-28 09:47 , Processed in 0.104160 second(s), 18 queries .
