oxy gasoline cutting torch - oPetrol cutting torch
发表于 2021-8-31 23:06:22 | 显示全部楼层 |阅读模式
It slices!  It dices!  It's the roncomatic 9000!Seriously.  Gasoline (125k btu/gallon) and propane (91k btu/gallon) have roughly the same heat output and cost about the same.  Actually, propane is about a third less right now.  This leads me to wonder how one could realize 90% savings in fuel cost.  It must be magic.-Heath
Reply:Great idea when gaseous fuels are not available. :')  When propane leaks it quickly goes into the air.  When I have worked with gasoline I always end up with some soaking into a sleave or glove.  I worked with a guy who had used one in the field and he said it cut fairly good.  After being stored in a tools shed for several months they couldn't get it to work properly and gave up.  The unit is quite specialized.
GMT+8, 2025-12-28 08:11 , Processed in 0.097324 second(s), 18 queries .
