severely broke head off a ___ horse power Ford
发表于 2021-8-31 23:06:21 | 显示全部楼层 |阅读模式
I ain't even going to print claimed horse power for all ya'll arm chair engine experts to take apart Its about the welding repair!Trick Flow small block Ford head, story is it had a nos problem. Head was in one piece when it came in. After I was gouging crack out the corner of the head fell off. Between the red lines is what was not cracked on the deck side, about 1mm thick, you can see its a different color. Made some dowels and bolted and clamped to good head to keep alignment. Preheat, weld with a356, post heat, pressure test, surface, grind welds. I suggested a replacement but customer did not want to purchase head and then send off to have cnc port job matched to good head. Oh well, made me some $. Lots of pics.Peter Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:some more Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:lastone Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Very niceLeo
Reply:Nice workLincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Great job, as expected...
Reply:It always impresses me what you can fix Peter, but it impresses me more is how this stuff makes its way to you! I would love to have jobs like ones u get come my way some day, Ill have to get goin on buying a tig welder first. What is your estimated life expectancy on something like that?Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by NVWVery nice
Reply:Always great threads. Thanks for posting, you're a true artisan.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:When i started to read your post i was going to say to chuck it, it can't be repaired, what i've just seen amazed me 100%, Thats a fantastic job repair, well done
Reply:Originally Posted by Drf255Always great threads. Thanks for posting, you're a true artisan.
GMT+8, 2025-12-28 09:55 , Processed in 0.127036 second(s), 19 queries .
