A simple question...
发表于 2021-8-31 23:06:18 | 显示全部楼层 |阅读模式
I'm not a professional welder, so I don't know this.  (not that knowing this will make me a pro)What does 1G, 2G, 3G, ect. stand for?  I see people saying they did a 4G weld (or whatever) but never understand what it means.Sorry for the ignorant question.  Thanks.
Reply:Here's a pic."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:good morning here are some of the designations, (G) is groove, and you also may see (F) which is fillet1G = flat groove weld2G= Horizontal 3G= vertical4G= Overhead
Reply:oldendum,Can you make that into a PDF and repost it?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:files to big to upload to the site so i had to use a hosting service but here is the file in pdf formhttp://www.filedropper.com/weldpos
Reply:JPG format Attached ImagesMauricio
Reply:Thank you very much. Now i can decode what i am reading!!!
GMT+8, 2025-12-28 08:11 , Processed in 0.101772 second(s), 18 queries .
