a couple of adjustable roller stands..
发表于 2021-8-31 23:06:17 | 显示全部楼层 |阅读模式
sorry painted over my welds... Attached ImagesThere is never enough time to do it right ; But plenty of time to do it over .
Reply:Good looking and should make a few usefull tool.
Reply:Perfect!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Welcome Lefty. Nice looking roller stands. What's the adjustable height range?
Reply:Neat project!Are your legs collapsible/foldable or fixed (not referring to the vertical adj.)?  Couldn't tell from the photos.
Reply:26" TO 3'4" . The rollers came off of my boat trailer... if I didn't hit it just right , they would leave black streaks all down the sides of the boat. Saw some stands at the Home Depot and thought they looked easy to make.Since I'm new to all this it was a good project to do making the saddle and miters. Attached ImagesThere is never enough time to do it right ; But plenty of time to do it over .
Reply:Here's a tip for finding decent rollers for your project roller stands...Call a local printer that uses mechanical printing presses. Ask them if they have any old used FORM ROLLERS. The ones I use (I own a print shop) are AB Dick 360 form rollers. They have precision ball bearings on each end and are hard rubber so they dont mar up your work yet have the solidity to make for very precision work. Nothing better. You can get them from about 12 inches (by about 2 inch diameter) up to 46 inches or more depending on the larger press sizes. They will give them away because if nobody asks, they throw them out.Deve
GMT+8, 2025-12-28 08:11 , Processed in 0.100496 second(s), 18 queries .
