Bed frame repair
发表于 2021-8-31 23:06:16 | 显示全部楼层 |阅读模式
Bed frame repair, why? because I'm cheapFirst grind the paint off and clean upWeld up the crack, Because crack is wack !Used a piece of scrap as a gusset.and the finish.Enjoy.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:3/32 red tungstonat about 100 amps not sure I was using the pedal on the machine.scrap piece was 1/8"Bed frame thickness not sure I didn't checkWill   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:you are supposed to post a video showing what caused the crack...:)
Reply:Originally Posted by weldbeadyou are supposed to post a video showing what caused the crack...:)
Reply:I've done that exact same repair...I don't need to go into how the bed broke --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Originally Posted by SteelwillNothing better not be going on its my eight year old daugthers frameOn a serious tip my youngest daugther was in there jumping on the bed.
GMT+8, 2025-12-28 08:29 , Processed in 0.104507 second(s), 18 queries .
