Anyone recognize this cooler?
发表于 2021-8-31 23:06:13 | 显示全部楼层 |阅读模式
See attached photo Attached ImagesAustin TX
Reply:Looks like a Bernard."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:that's it - thank you!One other thing - sometimes when I look at Syncrowaves online, the preflow and post flow controls seem to not have any knobs.  Like there is a little plastic blank where the knob should be. Is this because they were sold without gas-handling parts as an option?Austin TX
Reply:Bernard yes but it also looks like a procon pump. Bernard I have has an oberdorfer pump. That one in the pic looks modified.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:The newer ones look like they have Procon pumps, judging from some rather small ad pictures."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2025-12-28 09:47 , Processed in 0.136706 second(s), 18 queries .
