Brazing
发表于 2021-8-31 23:06:13 | 显示全部楼层 |阅读模式
I tried to braze a piece of copper to the underside of my welding table so I could use it as a reliable grounding area.  I used Lincoln Electric bronze brazing rods.  The rod melted, but neither stuck to the steel nor the copper.  I used an oxypropane torch. I'm thinking I just didn't get the entire piece hot enough and the rod melted from the flame instead of the metal to be joined.  Any ideas?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:did you clean the metal and use flux? brazing involves a capillary action into a fitted joint..generally in various processes heat the metal and let that heat melt the filler..do not directly heat filler..
Reply:Try getting the table hotter.
Reply:"Butter" the thicker metal prior to attempting to attach the thinner metal. In doing this you will only need to reheat the brass and not the entire area of the thicker metal.Thanks,HoboLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Will shortening work in place of butter.  we don't use butter.  Mac
Reply:Originally Posted by Tool MakerWill shortening work in place of butter.  we don't use butter.  Mac
Reply:yeah man, you can tin each side, or just the side that's more difficult to heat at least... you do this just like soldering, heat the metal enough that it's hot enough that it melts the filler, not the torch melting the filler, and def need fluxmiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
GMT+8, 2025-12-28 08:10 , Processed in 0.072361 second(s), 18 queries .
