How much is this welder worth paid 400.
发表于 2021-8-31 23:06:11 | 显示全部楼层 |阅读模式
Old lincoln idealarc 250-AC-AC tombstone welderSent from my SM-G900P using Tapatalk Attached Images
Reply:Did you over pay, possibly.But worth every cent.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:A bit much for an AC welder, though location is everything.  However, I think it is perhaps an extremely early example of the kind.  Green faceplate and a green plate around the switch ..."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thank you I figured I paid too muvhSent from my SM-G900P using Tapatalk
Reply:Thanks I figured I paid too muchSent from my SM-G900P using Tapatalk
Reply:If it works and does what you wanted the price isn't really a factor after a while. But you will see AC/DC versions for $300-500 as you look around more - so don't let it get you down.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:ThanksSent from my SM-G900P using Tapatalk
Reply:Also look at it this way, your great grandkids will enjoy it too. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I bought a circa 1952 Lincoln AC-180C welder for $50. just because it was cool and I didn't want to see it go for scrap. Look up the serial number/code number on that old welder and see when it was made."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Where do you look it up to see when it was made , thank youSent from my SM-G900P using Tapatalk
Reply:The serial number is 107721 code 3491Sent from my SM-G900P using Tapatalk
Reply:Could someone please tell me the age and any other info from serial number 107722 code3491Sent from my SM-G900P using Tapatalk
Reply:Did any leads come with it when you bought it???
Reply:Here's a link I found that might be helpful. That welder will outlive us all nice score!http://www.lincolnelectric.com/asset...oln3/im206.pdfThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Also are you in the canned vegetable black market? I could use some cornThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Thanks the corn is a.friends going out of business saleSent from my SM-G900P using Tapatalk
Reply:Nice welder.  My grandfather taught me on a 180 AC Lincoln back In the early 60s and it was a great machine.   I think you will find the machine your purchased to be constructed with pride and quality components.
Reply:1957 year model.
Reply:Thank you Sent from my SM-G900P using Tapatalk
Reply:Those are great machines, I just bought one and restored it this summer.  My grandson's can finish wearing it outSent from my iPad using TapatalkSteveLincoln IdealArc 250Lincoln SA200 1966 RedfaceSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Originally Posted by duquesneOld lincoln idealarc 250-AC-AC tombstone welder6Sent from my SM-G900P using Tapatalk
Reply:Originally Posted by duquesneOld lincoln idealarc 250-AC-AC tombstone welderSent from my SM-G900P using Tapatalk
Reply:I paid $100 each for five of the AC/DC version of this welder at an auction in Cincinnati last year.  Several of them came with 25-50' of 1/0 leads as well.  However, my machines we more beat up, had been brush painted with white paint, and a couple had some knobs missing.  Yours is prettier.  I won't say you overpaid, but your price makes me happy with mine. The restored machine is a beauty!  I was just going to do a quick repaint, but that inspires me to try a little harder with mine!
Reply:400 isn't bad for the fact its bulletproof okay a lot more than bullet proof.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:Originally Posted by woodtick007I would say you paid 2wice as much as you should have.   Did you not research before going there?   Were you on booze or pot at the time of purchase?  Well its yours now....lets just hope you don't have to put any money into it.Slightly overpaid, however, you will make it back quickly. I have thousands in welders, and each one paid for itself very quickly. If you don't know how to use it, take a class, or find someone who will teach you. It will add to your enjoyment to do it successfully and easily. I have wasted more money on new tools that dont work as advertised so far this year than you overpaid, so you didnt get bit too bad. Enjoy your new welder.
Reply:BTW,  pull the cover and blow it out, then sand and paint the cover, it will immensly improve your attitude toward the welder. You can also do a search for how to add a rectifier to your machine to make it DC as well.
Reply:Its ok will pass down to your grandkids ,blow it out and paint it up weld with 1/4 rods all day long. You can buy AC carbons and gouge too. Add a dc convertor and Hi Freq box and tig away.
GMT+8, 2025-12-28 09:51 , Processed in 0.067511 second(s), 18 queries .
