Dual core without gas
发表于 2021-8-31 23:06:07 | 显示全部楼层 |阅读模式
Just wondering if dual core can be used as flux core without CO2 shielding gas?   Only asking cuz I have no use for dual core and the welder I just got came with a full 33 lb spool of ultracore 71c.   If not I will prob just give it away at the next Weld-o-rama if any takers.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I would not think it would work. I never have but always wanted to try if you are giving it away and shipping was not bad I would float you a little extra. What size is it?
Reply:From my experience (not slot) it does cause porosity If you don't use co2 with dual shield  Sent from my XT881 using TapatalkUsing Tapatalk
Reply:The results would not be good. Probably not as bad as hard wire without gas but not really useful even for non-critical messing around. I would either get a bottle of CO2 or get rid of it.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Nope, will not work. makes a nice spongy mess, though.
Reply:It makes a lighter weight weld. But no not really it will not work
Reply:lol, lighter weight welds is right. I'm sure someone has found a use for those, some might consider them artistic!
Reply:It's .045. It should fit in a large priority mail boxLast edited by soutthpaw; 07-06-2014 at 10:51 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Dual shield without gas welds worse than solid core without gas.  Even a slight breeze really messes with dual shield welding.
Reply:Originally Posted by 76GMC1500Dual shield without gas welds worse than solid core without gas.  Even a slight breeze really messes with dual shield welding.
Reply:7018 on a roll baby! Right? At least that's my understanding. Its the go to for structural work in my area where we worry about earthquakes.
Reply:Hello soutthpaw, dual shield(technical name gas shielded flux-core arc welding wire: FCAW-G), has to be run with a shielding gas. There are some of the wires that are designed to be strictly used with CO2 shielding gas, some that are designed for use with 75Ar/25CO2 only, others designed for use with either of the aforementioned gases and still others that can be run with higher percentages of Argon as a part of the shielding mix with CO2. You will only know by the designations that are listed on the particular gas shielded flux-core arc welding wire. Flux core arc welding that is done without gas is specified as such(self-shielded flux-cored arc welding: FCAW-S) and is not to be run with a shielding gas. Detrimental metallurgical results will become a part of the weld metal if you introduce a shielding gas to the self-shielded wire. That's the short of the answer, there is a lot more that could be added here to explain all of the specific details. Best regards, Allanaevald
Reply:lol at "whats the point?"I have often wondered the same thing myself without much of an answer. best I got was: "next to strait f.c., less smoke, less spatter"I will say I feel less inclined to throw 232/233 around pipe than I am to throw some outershield. something about the stuff really is magicbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Originally Posted by Joedan7018 on a roll baby! Right? At least that's my understanding. Its the go to for structural work in my area where we worry about earthquakes.
Reply:Originally Posted by soutthpawSo what is the point of dual shield?
Reply:And you get the best of both worlds. Gas, and slag coverage. Then there is always the speed, time is money! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:We have one booth at the welding school set up with it.  Sure deposits a lot of metal and pretty as well.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Someone once described it to me as butter. And that is exactly how I imagined it to be without ever using it. 7018 is not butter to me.
Reply:Dual shield requires gas shielding. The point of the dual shielding is because unlike er70s-6 solid mig wire which is a fast freeze wire, dual shield is not; to really burn in on thick steel sections like structural and pipe welding you need a ton of heat to generate a big fluid puddle that is capable of smoothly accepting high deposition rates of filler; you don't want a fast freeze mig wire. A slag shielding over the weld is required because the weld is still molten after the gas shielding zone has passed by. The inner shield is flux, like the outside of a stick rod. Dual shield is literally the stick welding process adapted to a wire feed process, which yields huge gains in deposition rate.Welding/Fab Pics: www.UtahWeld.com
Reply:You are throwing the best wire made ,we ran over 100 tons of it on the world trade center .045 & 1/16 co 2 shielded , dual shield is that Esab pos.  D1.8 &D 1.5 certified too!
Reply:I will take it southpawSent from my iPhone using TapatalkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
GMT+8, 2025-12-28 09:53 , Processed in 0.110600 second(s), 18 queries .
