sidekick miller low output
发表于 2021-8-31 23:06:07 | 显示全部楼层 |阅读模式
talked to miller about my welder and they say the rectifier is out need some help please
Reply:Like this ?:http://weldingweb.com/vbb/showthread.php...de-rect-bridge
Reply:no mine has 4 panels with pressed in diodes. I dont see that bridge anywhere in my welder !
Reply:You might go here and enter your serial number,at least find out what the part number for the parts are.:http://www.millerwelds.com/service/o...uals.php?model
Reply:Thank you i got the part number from Miller but hate to spend 150.00 and that not be the problem. Is there a way to test it?
GMT+8, 2025-12-28 08:19 , Processed in 0.093303 second(s), 18 queries .
