Cast dairy metal
发表于 2021-8-31 23:06:06 | 显示全部楼层 |阅读模式
I was wondering if anyone has ever welded cast dairy metal back together?  If you have, what did you use to weld it with as far as filler metal.  I am running into issues at work with these cast clamping pieces breaking.  The lead time to get new ones is 6 weeks if our procurement gets the order in a.s.a.p. The pieces are 2" thick and 4" wide by 6" long and look something like a c-clamp.  Any advice is welcome.    Thanks, Paul
Reply:Yikes.  http://www.anchorbronze.com/c97600.htm"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Wow!! That says a mouthfull.  Thank you for the reply.  I guess it's time to look at different material options for these parts.
Reply:What do you have a batch freezer repair or something?  If you're repairing dairy metal that's in direct contact with human  food, I'd avoid the project all together.  Unless it's a dairy metal appliance made within about the past 10-15 years, there's too much lead in the cast metal.  IIRC, old cast dairy metal is around 4-5% lead. "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
GMT+8, 2025-12-28 08:12 , Processed in 0.072307 second(s), 18 queries .
