Miller nozzles for 211 Mig
发表于 2021-8-31 23:06:06 | 显示全部楼层 |阅读模式
Gents, I just took the leap of faith and decide to go with a used Miller 211MVP.  I’ve done a few little projects around the house nothing major, mostly exhaust work.  I’m still trying to dial in my beads.  With this said I’m looking at consumables.  I seen that the tips are not compatible with the Lincoln tips I have in my tool box.  So I take it everything has to be Miller?  Also I find it hard to believe that the Mig nozzles are going for 14 bucks each at Westair or Airgas.  Is there any other places I should look to order?Westair said I should get the Nozzle gel to make the Nozzles last longer.  Any other ideas or help is greatly appreciated.
Reply:eBay.  WeldingCity or USAWeld.  CheapNozzle gel works OK.
Reply:what drf255 saidMillermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:I like the spray non stick, or just plain PAM cooking spray (same thing repackaged). The nozzles last a long time too, not a huge expense.
Reply:$14.00 while a tad bit high, isn't going to break the bank.  It's not like you're going to go through the nozzle on a weekly basis with that 211. .Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by dem0nk1dGents, I just took the leap of faith and decide to go with a used Miller 211MVP.  I’ve done a few little projects around the house nothing major, mostly exhaust work.  I’m still trying to dial in my beads.  With this said I’m looking at consumables.  I seen that the tips are not compatible with the Lincoln tips I have in my tool box.  So I take it everything has to be Miller?  Also I find it hard to believe that the Mig nozzles are going for 14 bucks each at Westair or Airgas.  Is there any other places I should look to order?Westair said I should get the Nozzle gel to make the Nozzles last longer.  Any other ideas or help is greatly appreciated.
Reply:I've got a 211 and have burned a lot of wire and am on the first tip and nozzle (0.030").  I bought a few extra tips and a nozzle at a local welding supplier but don't remember the cost, I believe it was very reasonable.  I only bought them for future use so I had them on hand.  Like I said, I'm still on the first tip and nozzle and have gone through two large spools of wire.  The nozzle doesn't get clogged up with spatter often so I just clean it out once in a while with a piece of scrap.  Most of what I weld is clean or I clean it well before welding however."All of this and some of that's the only way to skin the cat!"
Reply:Less than $20 (delivered) for a pair (2) of them off of EBay.  Original Miller parts sealed in their original packaging.  Several regular dealers sell them there, all within a dollar or two of each other.
GMT+8, 2025-12-28 09:48 , Processed in 0.115527 second(s), 18 queries .
