Help with unwarping Aluminum plate
发表于 2021-8-31 23:05:58 | 显示全部楼层 |阅读模式
48x36 base, all 1/8" plate or sheet with 10 inch sides..This is an oil tank with 2 compartments. I got all of the sides on (4) and went to put in a cross section  and the middle bowed out.. About a half inch as of yet while tacking.3/32 tung, 7 cup, I have a torch if needed, I might just try to clamp it back into place but those are at the stop.From what I have read I got into it too quick and should have taken a slower approach with preheating..Tried Tigging spots on the underside to see if it would go back, and no luck. Decent at running tig/Aluminum beads, I suppose my aluminum fabrication should use some work.Thanks in Advance.14' PowerMig 210 MP13'Burntables 5x10 CNC Table14' SAE300 HE on a 12' Ram 4500 60 CA 4x4. Custom bed/bottles/reels.87' SA250d, 78 SA200,11' Ranger 250 GXT AC/DCThermal Dynamics Cutmaster 8112' Lincoln Precision Tig 22508' LN25
GMT+8, 2025-12-28 09:54 , Processed in 0.111545 second(s), 18 queries .
