Wheels For A Truck Rack
发表于 2021-8-31 23:05:54 | 显示全部楼层 |阅读模式
My truck rack costs me about 1 MPG to carry it on my truck. And since I don't use it on a regular basis I don't want to haul it around if I don't need it. I needed a way to move my truck rack after taking it off my truck. I have a set of A-frames to load/unload it, but can't leave it there after taking it off, the space is also used for parking, and also is the entrance to the double doors on my shop. So I came up with a way to temporarily attach some wheels to move it to a better storage area out of the way.So this is what I came up with. I used 2 pieces of 2.5 x 2.5 x 1/4" & 2, 2 x 2 x 1/4" angle iron 5" long and 2 pieces of 5/8" rod for the axle. They just slip onto the angle iron of the rack bed rail pieces and I can roll it around like a wheel barrow. I clamped the 2.5" & 2" angle to another 1/4" piece of angle to set the distance between while also clamping the 5/8" rod on the other end. I then welded on each side of the rod to the angle iron, both pieces. Now when I remove the rack I can slip these onto the bed rail pieces(at the balance point)and move it, or bring it back to the A-frames to put it back on the truck. It's a tight enough slip fit it doesn't need set screws or any method to secure it to the rack for no more than I need to move it. I think some of you folk might be able to use this idea for the same reason I needed it. My rack is too heavy to easily move by myself, and is a chore still for 2 to move. Attached Images
Reply:That is one clever wheel mount design. Super simple yet very effective. Good job!
Reply:Originally Posted by Bistineau My rack is too heavy to easily move by myself, and is a chore still for 2 to move.
Reply:Originally Posted by DSWHave you considered a breast reduction? Nice idea. Bigger wheels might have helped some. We used to have a "cart" using a few old wheel barrow tires we used to use to move one of the truck racks with on occasion.
Reply:Breast reduction  "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammBreast reduction
Reply:B', I really like the practical design of your dollies, but mum's the word on the mpg loss caused by racks!A couple years ago here in Libralville, the hippies were trying to pass legislation bannng ALL racks and aftermarket accessories the reduced factory mpg rates!  Now we have some "well meaning politician" who wants to make it mandatory that you must have a doctor's prescription to buy cigarettes!!  Basterds need to mind their own business!Anyways, where was I going.....oh yea, "breast reduction".......heheLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by dubl_tB', I really like the practical design of your dollies, but mum's the word on the mpg loss caused by racks!A couple years ago here in Libralville, the hippies were trying to pass legislation bannng ALL racks and aftermarket accessories the reduced factory mpg rates!
Reply:Originally Posted by Bistineau..... I bet the ones pushing for all this, only drive cars or something less than that, not a one of them owned a pick-up truck.
GMT+8, 2025-12-28 09:52 , Processed in 0.122636 second(s), 18 queries .
