Glass Lift steelwork and associated steels
发表于 2021-8-31 23:05:52 | 显示全部楼层 |阅读模式
Since Novemeber last year i've been welding the steel work for the PWC Redevelopment in London, they are for the different Floor levels and the 220mm steel tubes for the Glass Lifts which go inside the Atrium.The redevelopment is to be undertaken in two stages, with PwC staff remaining in part occupation throughout the redevelopment works. The redevelopment is due to complete in August 20131 Embankment Place is owned by the Sultan of Brunei and the 12-storey London icon accommodates 4,000 PwC staff across12 floors, providing a total of 346,000 sq ft of West End office space. The complete work is costing in the region of 40 million Pounds.Prior to lift shaft being constructed a there have been a large amount of works carried out to the existing structure to provide additional strength to allow for the additional loads.The lift shaft has been built from top down starting with a complex truss arrangement, the steel shaft then runs through the atrium of the building which is still holds 2,500 occupants while the works are in progress.This truss was been part fabricated in sections to allow for restricted deliveries via the goods lift. The second part of the fabrication has been carried out on site fully welding the sections together to form the structure.Following on from the truss the lift shaft is made up of vertical circular hollow steel sections with steel frames tying back into the structure at each level. On alternate levels a new slab is formed extending out to the new lift shaft.Welding the Steelwork at the workshopYou can see the scale of the project in this You Tube Video, The first 15 secs are the wrong way up but after that you can just about make out the  tubes of the lifts in amongst all the scaffolding
Reply:What machine was you useing to do weldingThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Originally Posted by RenagadeWhat machine was you useing to do welding
Reply:You get all the fun jobs...However some places frown at having their prints out in the open......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:those are some very pretty welds!
Reply:Originally Posted by MJMetalworksthose are some very pretty welds!
Reply:Originally Posted by zapsterYou get all the fun jobs...However some places frown at having their prints out in the open......zap!
Reply:Very cool and very nice welds...I think Zap was specifically talking about the blueprint...not your bad *** welding and fab...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by DemonSpeederVery cool and very nice welds...I think Zap was specifically talking about the blueprint...not your bad *** welding and fab...
Reply:Great work Gerry I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeGreat work Gerry
Reply:That's great looking work.IW Local 580 NY, NY
Reply:Wow!  I thought some of those welds were sub arc! Holy sheet, man. POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:I think you might be good enough to build your own trailer.  Mac
Reply:Originally Posted by SMC WeldcraftWow!  I thought some of those welds were sub arc! Holy sheet, man.
GMT+8, 2025-12-28 08:18 , Processed in 0.095536 second(s), 18 queries .
