Tungsten/Filler Rod for mild steel
发表于 2021-8-31 23:05:48 | 显示全部楼层 |阅读模式
I'm piecing together a low budget TIG setup to get my feet wet with TIG.  I've been welding thin wall tubing with a 110v Bluepoint MIG up until now and am curious what Tungsten to run just to weld mild steel?  Also, what filler rod?  Would stainless filler rod just be a pain?Thanks in advance guys
Reply:Depends on the machine you r using,  Lanthanated works good for inverters.  Buy it via ebay. Cheapest way to go.   Still hard to beat the 140ST from everlast or longevity for a cheap tig setup. 140 amps is a good amount of current for DC tig.   Try and score yourself a used dc tig machine.  Most end up coming with extras like consumables and often cylinder and regulator...And please try using the search function this is a topic that has been covered hundreds of times.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:2% thoriated is the best and cheapest for DC welding.Er70-s2 is the cheapest and best for mild steel.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by soutthpawDepends on the machine you r using,  Lanthanated works good for inverters.  Buy it via ebay. Cheapest way to go.   Still hard to beat the 140ST from everlast or longevity for a cheap tig setup. 140 amps is a good amount of current for DC tig.   Try and score yourself a used dc tig machine.  Most end up coming with extras like consumables and often cylinder and regulator...And please try using the search function this is a topic that has been covered hundreds of times.
Reply:Originally Posted by zeus_r6Thank you sir, I was in a rush and didn't search sorry about thatThese?http://www.ebay.com/itm/10-2-0-Thori...item2ebbe53d49
Reply:What would be a better price?
Reply:Originally Posted by zeus_r6What would be a better price?
Reply:What type of filler rod should I be looking for to use for mild steel?ThermalArc 181i | Lotos WS200
Reply:Er70s-6Mauricio
Reply:Originally Posted by mauricio_daniel_62Er70s-6
GMT+8, 2025-12-28 08:18 , Processed in 0.207441 second(s), 18 queries .
