roof sheeting in cyclone rated areas
发表于 2021-8-31 23:05:34 | 显示全部楼层 |阅读模式
hi there i was wondering if anyone could tell me what is the best material to use for roofing in cyclon rated areas.im using 316 stainless patio tube for the frame any recomendations for roof material?thanks trev
Reply:What Cat cyclone area are you in?
Reply:1st stop should be to ask manufacturer's of the roofing for their recco.For this structure to functionally survive tornado wind force, requires someengineering.Last edited by dave powelson; 07-15-2014 at 02:20 PM.Reason: additionBlackbird
Reply:You could build a tornado proof frame and cover it in inexpensive  tin so when it blows off you can replace it cheap just a thoughtSent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
GMT+8, 2025-12-28 11:55 , Processed in 0.098475 second(s), 18 queries .
