Where to buy 1/4" or 3/8" square steel Tube in south east USA? or custom made?
发表于 2021-8-31 23:05:31 | 显示全部楼层 |阅读模式
Just started using steel to make some light weight trade show stuff. I like how rigid steel is compared to aluminum tube I've been using but the extra weight is not good, so I'm going with very thin walls. Does anyone know of a company that makes/sells very skinny steel tube like 1/4" wide by 1/2" rectangular tube? or 3/8x3/8" square tube or something like that.I got some steel BAR from alro.com that is 5/16 x 1/2" but the stuff flexes more than I care for and it's heavy stuff when an average structure is 150 linear feet of it  at .6 lb/ft.  why does bar flex more than tube? Must be due to the internal geometry?!?http://www.tottentubes.com/square-steel-tubing californiahttp://www.aladdinsteel.com/products..._steel_tubing/ illinoisean of course mcmastercarr sells it for very high prices. I googled a few above, but hopping to find south east coast supplier of the 3/8x 3/8" tube or if I can find 1/4x1/2" that would be cool too.With aluminum I could buy a die for $1700 and a minimum order of 1000 lbs and get any shape i wanted. can you do something similar for steel? Obviously it's not extruded but is getting custom tube sizes in steel just as simple?
Reply:Nowhere down south,  they only make all that stuff up North and out West.
Reply:Sorry double postLast edited by AluminumWelder; 07-13-2014 at 08:30 PM.
Reply:Most metal companies distribute steel products they don't actually make every thing they sell, so your response doesn't really make sense to me I buy aluminum made in USA and China from eastern metal and they are next door to me
Reply:How far are you from Tampa Florida?
Reply:[QUOTE=AluminumWelder;4412061]  why does bar flex more than tube? Must be due to the internal geometry?!?Surface area. Square tube has nearly twice the surface area of bar stock. So it was once explained to me anyway.
Reply:I'm 9 hrs away from Tampa, but distance is not that big of a deal. If I could find a 1/4" wide tube either square or rectangular I'd order a few hundreds sticks and have them cut down and shipped via truck on a palette. 3/8" square is somewhat rare, but not impossible to find, so I'm seeing if I can get that locally first.
Reply:Originally Posted by AluminumWelderI'm 9 hrs away from Tampa, but distance is not that big of a deal. If I could find a 1/4" wide tube either square or rectangular I'd order a few hundreds sticks and have them cut down and shipped via truck on a palette. 3/8" square is somewhat rare, but not impossible to find, so I'm seeing if I can get that locally first.
Reply:called up lousiana steel since their web site says they do custom , but they said that size was too smallhttp://www.louisianasteel.com/videos.htmlneat video showing how the process is done though, too bad it is so blurry.
Reply:3/8"http://www.aladdinsteel.com/products...Fcvm7AodY2UAXQ"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Altho more expensive than mild steel, aircraft grade 4130 tubing is available in 1/2 x 1/2 x 0.035 wall (0.221 lb/lin. ft.) from homebuilt aircraft materials suppliers like Aircraft Spruce ( http://www.aircraft-spruce.com/catal...4130square.php). Wicks Aircraft is another I have bought from. They also show 1/2 x 1/2 x 0.065 wall mild steel ERW (electrical resistance welded) tubing that is lots cheaper than the 4130. It will be nearly twice the weight per lin. ft. of the 0.035 wall "good" stuff.Both will ship via UPS (within size & weight constraints, of course). For larger orders, truck shipping should be more cost effective & quantity discounts may be available.Lee
Reply:[QUOTE=12V71;4412951] Originally Posted by AluminumWelder  why does bar flex more than tube? Must be due to the internal geometry?!?Surface area. Square tube has nearly twice the surface area of bar stock. So it was once explained to me anyway.
GMT+8, 2025-12-28 10:11 , Processed in 0.117416 second(s), 18 queries .
