Bending Angle Iron
发表于 2021-8-31 23:05:23 | 显示全部楼层 |阅读模式
can you bend say half inch angle iron with a cheapy shop bender made for bending flat, round and square stock? Im talking bending it with one flat edge staying horizontal and the other verticle.Last edited by coachgeo; 01-01-2006 at 09:53 PM.
Reply:I think a shrinker might be the tool to use here.Well, you could try some and see how it works?Owner of Welding Wiki,The free wiki based resource for weldor's around the world.http://www.weldingwiki.comWe have cookies!
Reply:Originally Posted by ctardiI think a shrinker might be the tool to use here.Well, you could try some and see how it works?
Reply:Sounds like some one is applying for troll status!!!
Reply:Originally Posted by KEENAVVSounds like some one is applying for troll status!!!
Reply:I am lost. That is twice now someone has thrown out there that Im attempting some trolling.  You got the wrong friggen guy if your thinking that route.  Heck I've moderated on bulletin boards for over 4 years now so how about we get back to bizI have a bender and  I need angle iron bent into about a 2 1/2 foot diameter cirlcle to make a different hatch to fit atop my Unimog. When I find a shop to rent and get set up I can try it myself.  Till then not a damn thing wrong with asking if anyone has experience bending angle iron.
Reply:Read my first post all the way next time before commenting.And just because you've modded for 4 years doesn't prove anything.   I administrate 2 webserver, so what?Owner of Welding Wiki,The free wiki based resource for weldor's around the world.http://www.weldingwiki.comWe have cookies!
Reply:Edit: For a bend with the 'flange' on the outside, you would hvae to use a special, home made die for your bender.  For one on the inside, use a shrinker.Owner of Welding Wiki,The free wiki based resource for weldor's around the world.http://www.weldingwiki.comWe have cookies!
Reply:Originally Posted by ctardiEdit: For a bend with the 'flange' on the outside, you would hvae to use a special, home made die for your bender.  For one on the inside, use a shrinker.
Reply:Originally Posted by coachgeoThanks for the info. I'll google up what I can find on this subject since discussion here is discouraged
Reply:I think for one, for your unimog, Harv hit the nail on the head with the weld together two flat pieces technique. You cannot bend angle iron with a hundred dollar harbor freight bender. Just wont do it. A real hossfeld will do it, but the bender is $800 new, and figger another grand for the angle tooling. I have bent a lot of angle with my hossfeld, and it works, especially flange in, but it is never perfectly flat- it bows a bit when you do it. Much better is my $8000 powered angle rolls- they will do what you want, no problem. So, if you insist on doing it yourself, try bending one flat bar the easy way, and one the hard way, and welding them together. Although I dont think bending flat bar the hard way is something those HF benders do real well. Once again, the hossfeld with the angle dies is great at this- but once again, 2 grand for one, new. Much better to just pay to have this done by somebody with powered angle rolls. I have a couple of places down the road from me who have them- a big sheet metal HVAC company, and an aluminum boatbuilder- and both will bend a circle like you want for maybe 50 bucks.
Reply:No,  you don't have to bend two peices, bend one peice of flat bar, and cut the other out of a peice of plate, weld together.Owner of Welding Wiki,The free wiki based resource for weldor's around the world.http://www.weldingwiki.comWe have cookies!
Reply:Originally Posted by ctardiNo,  you don't have to bend two peices, bend one peice of flat bar, and cut the other out of a peice of plate, weld together.
Reply:Maybe make the donut in 3 pcs? That way you get it out of flat bar, not a big pc of plate
Reply:Originally Posted by TEKMaybe make the donut in 3 pcs? That way you get it out of flat bar, not a big pc of plate
Reply:More on this subject athttp://weldingweb.com/vbb/showthread.php?t=4033
GMT+8, 2025-12-28 10:11 , Processed in 0.101543 second(s), 18 queries .
