Couple Project Pictures
发表于 2021-8-31 23:05:14 | 显示全部楼层 |阅读模式
I haven't had much time to check the threads here lately. Fortunately that is because the shop has been busy.But here is a couple pictures of a project we just completed. It is a custom built rack to hold plate type machine parts vertically. It replaces a shelf type unit that made finding parts difficult due to stacking them on top of each other.The 2 lower sections are designed to store crates which some parts are stored in.Rack was designed and fabricated by Accurate Design and Fabrication. Paint was done by Soucie Industrial Paint. Snow on the rack was provided by Mother Nature. Al Attached ImagesA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Interesting... What materials did you use?
Reply:The framework is square and rectangular tubing. 1x1.5x.120 and 1.5x1.5x.120. Rest is 14 Ga. HRS.AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Nice. I'm guessing there's a bit of mass to them.
Reply:Somewhere around 800 pounds. Built for an industrial plant.We don't build light duty equipment. AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Nice work Al. Did you have any battles with warpage? I see you won, if you did, looks great. I'm surprised they didn't want fork pockets. I gave you a call not too long ago, I'm glad you're busy. Give me a ring when you get time, we can catch up."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:We used every clamp in the shop on the sheets while welding them in place. But the 14 Ga. stayed pretty flat. Bought the sheets sheared to size and they fitted up good.We had some height restriction where the rack was going. Once in place it should pretty much stay there. So we didn't add any lift provisions. Got your message and completely forgot to call you back. These days it's all I can do to remember my own name. I'll get a hold of you this week.AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
GMT+8, 2025-12-28 10:11 , Processed in 0.073042 second(s), 18 queries .
