Jigging it up
发表于 2021-8-31 23:05:14 | 显示全部楼层 |阅读模式
I am building a  jig around a turbo manifold I had designed so I can recreate it later on.  Its big steel (1/2" plate and I think 3/4" square bar..).I know I am welding with hardly enough power, but I am limited to 125A so I am having to make multiple passes.  But, in doing so, I am getting the hang of walking the cup:Jiggin' it by Jon Kensy, on FlickrJiggin' it by Jon Kensy, on FlickrNot too concerned with penetration other than wanting it to hold shape.  The goal is to locate the turbo flange with respect to the head flange, which this should do just fine.Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:Lets see the entire jigMiller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Originally Posted by astaindsoul5446Lets see the entire jig
Reply:Not to shabby and ya i'll third that
Reply:Here's the thing as a wholeFinished Jig by Jon Kensy, on FlickrRealize the flange placement to the header flange isn't square so the square bar had to have some angle in the joint near the rear part.Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:Looks like it's going to be a fun project. You need to get some small square tubing and give that poor little welder a break lolWelding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverLooks like it's going to be a fun project. You need to get some small square tubing and give that poor little welder a break lol
Reply:Cool fixture.Syncrowave 300Maxtron 450, S-52E, 30A
GMT+8, 2025-12-28 10:11 , Processed in 0.072276 second(s), 18 queries .
