Coupons... what to do?
发表于 2021-8-31 23:05:09 | 显示全部楼层 |阅读模式
So over the months, I've been practicing on some coupons.  They're about 1/2" to 5/8" thick, 6" long, some are 5" wide, others are about 3" wide.With the break in the heat today, I was cleaning up around the place, and have about 20 pounds of this stuff.What do I do with it?  I guess I could scrap it, but not sure it'd be worth my time/fuel.  It's too ugly to use as "art" lol.Suggestions, please.
Reply:Start a Scrap bin/buckets and when you get enough, it will be worth the time and gas.I took some of my scrap and it came to $36.00 bux and it really wasn't that much stuff, granted the Scrap yard is pretty close so not a lot in gas or time but it paid for a few brews.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Yeah, I took one of those old extra large milk crates, flipped it upside down, put a piece of 3/4 ply under it, added casters, then threw the scrap in there. There's a scrap place about 7 miles from me. Will probably call to see what the going rate is.
Reply:throw it piece at time in the old ladies trunkwhen you see the car start to sag, send her to the scrapper and tell her to spend the money reward to follow
Reply:If you've only got 20 lbs, you haven't practiced much.'My name's not Jim....
Reply:You didn't mention material type.  You can sell on eBay as welding practice coupons.  I bought 5# of aluminum coupons on eBay from Insterno.  That's how I learned alum TIG.  You'd be surprised to see how little coupons are advertised for sale.  Im sure there's a market out there for them.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by BoostinjdmIf you've only got 20 lbs, you haven't practiced much.'
Reply:Depends a lot on what you are doing. The tech school cuts a lot of the coupons up and reuses them. This is especially true wit ones used for outside corner and T joints. Lap welds no so much if the students do what they are told and form a set of steps vs simply doing one weld on a pair of coupons and then tossing it in the scrap barrel. This also gives the students practice cutting with OA and plasma.3/8" bevel plates usually get recut about 1/2" back and used again as well. Most times the guys screw up the roots, and there really isn't all that much that's "wrong" with the coupons and a quick pass with the track torch adjusted to cut 1/4" smaller than the original will clean up the pieces. Once the bevel coupons are really too small to use, they can be used for basic stick practice on other joints like Laps and T'sBeing smart and thinking a bit when you go to weld will allow you to maximize your materials and reduce the amount of "scrap" that you have to toss..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I would agree with all of the above.If you have room start a scrap pile.  Kinda a problem for me as I am in the city, but I can hide most of it so I am fine.Currently my big money maker will be an S10 axle I got for free, it's all cut up so only the internals will be any good.  Otherwise I have scraps of swing set pieces, nuts/bolts, small pieces left from projects, etc...I have also been given a rim off a Dodge pickup, 20" so it has a little weight.Sometimes telling people you take in scrap will help you collect.  On the same note just like taking yours in going to pickup a washer or dryer is not worth the gas money for what you get back.Something to consider is how much money you will get to the distance you have to drive.  I do not go looking for scrap, just have a few people that will give me stuff when I am at their house, or at work.Also like said if you can cut it up more and practice with it, or sell it for practice go for it.  Just sell it for more then scrap prices.
Reply:If you have the means / time, cut the weld out + the HAZ and re-weld on them! put that expensive steel to good use!
GMT+8, 2025-12-28 10:11 , Processed in 0.098549 second(s), 18 queries .
