TIG ? Check your pulse?
发表于 2021-8-31 23:04:59 | 显示全部楼层 |阅读模式
I was teaching my new apprentice to tig weld today and he asked how often I use a pulsing technique. I thought about it for a second and realized that I pulse almost everything, probably 75% of the time or more. What percentage of the time to you guys pulse?Ian TannerKawasaki KX450 and many other fine tools
Reply:Are you talking about setting the pulser on the machine or simply "pumping" the pedal.In general I do neither except on rare occasions. I have seen very slow pulse settings used to train guys to dip filler regularly..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I will be interested to see the replies on this.  I tried it a bit over the summer and though it was cool and I could see potential applications for it, I decided it was going to be a crutch for me learning to TIG Aluminum...  Never tried with MIG..Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I mean pumping the pedal, in a coordinated manner with dipping and moving.Ian TannerKawasaki KX450 and many other fine tools
Reply:Sometimes I will build a new stack for a boiler, and I like to pulse, but I only see it useful on light gauge/thin material. I think pumping the pedal or setting the machine to do it for you is one in the same. Anything 14g and thicker is done with steady current.Constant Current Weldor.
Reply:Not too much, generally.When I was taught to Tig Aluminum it was described to me like this:The most likely place to have a crack start is right at the beginning of a weld, or right at the end.When you pulse like that, you are creating a bunch of starts & stops.Buy American, or don't whine when you end up on the bread line.
Reply:Originally Posted by WeldingMachineWhen you pulse like that, you are creating a bunch of starts & stops.
Reply:I would love to try one of those inverter machines man. I just cant justify the $, got too many things going on, but they sound sweet. I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Pulse welding aka "pumping the pedal" is the only way I weld 4130 round tubeMiller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:4130, I tig like that all the time, set the machine at a high end of what is required. I dont like using the pulser for aluminum much unless Iam 1/8 or thicker never caught on to it on thinner material
Reply:Originally Posted by jontheturboguyPulse welding aka "pumping the pedal" is the only way I weld 4130 round tube
Reply:Pulse...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by MikeGyverWhy is that? I do a fair amount of tig rollcage work and have never found pulsing useful. I just set it at about 130amps and go.
Reply:Originally Posted by zapsterPulse...zap!
Reply:Originally Posted by DSWZap you are a tig welding machine. There's some debate here whether you actually have a pulse or not....
Reply:Originally Posted by jontheturboguyI was tought to weld 4130 by a man whos welds continuously go down the track @ 300+ mph."Boy if you loose the color on 4130, you better have an oxy fuel torch in your hand..."
GMT+8, 2025-12-28 10:11 , Processed in 0.073823 second(s), 18 queries .
