I have a 1981 corvette project that has some cracks in the frame. I have the car in my garage in Santa Ana CA and have removed the control arms, power steering unit, pump, and everything else that would be in the way to give the best access to the area. I have also cleaned up all of the areas where the cracks are as best I can.Might need some reinforcing also. An aircraft engineer friend said tig would be best, but I'll leave that up to the experts. Please pm me if you are interested.Thanks!!Last edited by zero1niner; 07-15-2014 at 01:12 AM.
Reply:The old messy weld was there when I got it. That part with the threaded studs was for the original power steering setup which I no longer have (was replaced by an aftermarket system that doesnt use that bracket anymore). Here are a few more pics.
Reply:Holy Seagull ****batman !!!!Backed my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Wow there's allot of clean up needed there Sent from my iPhone using TapatalkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I could do some or all of the cleanup myself. Clearly it's not a show car. It's a daily driver. I only care about making it solid and safe.
Reply:Wow... just wow!You get what you put in and people get what they deserve...
Reply:my advice would be to grind all the old crap off before attempting to add re-enforcement and to find out what is causing the frame to keep cracking or you're going to be doing this again.i.u.o.e. # 15queens, ny and sunny fla
Reply:Gotta say guys,I have a '69 and the factory welds ain't much better. Shockingly bad from factory. Same frame. DOC is right. You need to figure out why it happened. Maybe add a gusset if room as well. If there's some major problem, it's just gonna find the next weakest link to break.Looks like someone had a field day with a 110 mig and flux core. Would the guys here that know what they're doing (not me) add a fish plate situated longitudinally and leave the crack alone? Isn't one not supposed to weld transversely across the axis of any car or trailer frame if it can be avoided?Last edited by Drf255; 07-15-2014 at 05:34 AM.
Reply:You really should stop jumping your Vette'!Is that a T-top by any chance?I've heard of those frames cracking from lifting while the doors are open.Buy American, or don't whine when you end up on the bread line.
Reply:mig weld that frame,.030 wire and an argon mix.vee out the cracks, and get rid of those puke welds..i'm 2 1/2 hours north of you..busy for the next two weeks though..face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Talk about some clean ! WOW ! Welding is the easy part, cleaning up all that $hit is gonna be fun .
Reply:i can do that job, no sweat..face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Looks like it must have had a snow plow mounted on it at some time.
Reply:Must be common. I fixed one for a guy last year in the same area. Cracks almost look identical. Wasnt that bad of a job at all.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:'bout a five minute job.
Reply:Originally Posted by BrianC'bout a five minute job.
Reply:Originally Posted by duaneb55Isn't that what the customer is supposed to say?
Reply:I can do it just did a frame crack repair on a f150 plus I'm in Santa Ana licensed and insured Sent from my iPhone using TapatalkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Do not repair it! It needs replaced. Once a piece of steel has enough stress cycles to crack that badly in multiple places, the rest of it is near the end of its fatigue life. You will be continuously finding new cracks.Dynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
Reply:Are you suggesting replacing the frame?
Reply:Originally Posted by zero1ninerAre you suggesting replacing the frame?
Reply:Oh look, a Wikipedia science link to back it up, that pours on the authority.Fix it, it'll be fine if done right.Mr. HE
Reply:Originally Posted by hddnisOh look, a Wikipedia science link to back it up, that pours on the authority.Fix it, it'll be fine if done right.Mr. HEzero1niner This is a desparation offer: because I don't want to be left-out/behind the 'Slow Drag' solutions.I can do this . . .Send me the frame - body off - I'm 800 milesaway. You pay freight both ways.I require 6K up-front - plus contingencies.The up-side: I have Military & Aero-Space weld certifications - the down-side is that that yourInsurance-Carrier will only recognize hack AutoBody repair.OpuspsThis includes post-weld frame straightening.
Reply:Originally Posted by hddnisOh look, a Wikipedia science link to back it up, that pours on the authority.Fix it, it'll be fine if done right.:
Reply:Cant let the perfect be the enemy of the good.
Reply:Haha, don't they all!!
Reply:Don't believe everything you read on Wiki. If your "afraid" to do it, leave it to an expert.
Reply:Originally Posted by 4sfedWas my explanation too complicated for you to understand . . . or are you just too lazy to read any of the references contained in the wiki link?
Reply:Originally Posted by hddnisIs reality too complicated for you to understand? Or, are you too lazy to source a new frame for him?You are claiming a certain type of failure, and missing all the other potential types of failure it could be. Mr. HE
Reply:Hey guys. Can I make a suggestion?The OP has been made a couple offers to do the repair by some with experience and confidence in this area. Should he work something out with one of them I'm quite certain he'll monitor the frame condition considering the current situation.If monitored as I suspect will be the case, it's highly doubtful the frame will suddenly come flying out form under the vehicle while motoring down the boulevard and trust he'll keep us posted should more cracks develop.Just a suggestion.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base! |
