PlasmaCam problems
发表于 2021-8-31 23:04:49 | 显示全部楼层 |阅读模式
My computer used to have XP on it. It was updated to Win 7. The computer won't communicate with the table anymore. It gives me an error code 2, and says that the port access driver needs to be started. No idea how to do this. Any help, would be much appreciated. Thanks
Reply:Contact plasma cam tech support. I'm sure they will walk you through it. You may need a new driverJasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Go on the pcam owners forum and post up and do a search.
Reply:Mick120 is the PlasmaCam information group(PigInfo) moderator. He will know the answer.But did you do go into the settings and do an autodetect?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:My older tracker cnc would not work either after uploading windows 7. The serial port routing for windows 7 is different than xp so it doesn't communicate to your interface box. I just got another version of xp and was back in business.
GMT+8, 2025-12-28 11:55 , Processed in 0.117439 second(s), 18 queries .
