thermal arc 202 welding machine will it weld 8mm plate in ali
发表于 2021-8-31 23:04:46 | 显示全部楼层 |阅读模式
hi there thinking of buy the thermal arc 202 ac/dc machaine its 200amps looking to weld some 8 mm alimium plate as il be doing some intakes ,question is will a 200 amp weld  8mm ? aliminium
Reply:Originally Posted by hoochhenryhhi there thinking of buy the thermal arc 202 ac/dc machaine its 200amps looking to weld some 8 mm alimium plate as il be doing some intakes ,question is will a 200 amp weld  8mm ? aliminium
GMT+8, 2025-12-28 11:55 , Processed in 0.098936 second(s), 18 queries .
