P&H Hi Freq part availbility
发表于 2021-8-31 23:04:42 | 显示全部楼层 |阅读模式
Looking for a "mica capacitor" Miller Electric Mfg. part number 31-602 if any one has any resources.Also looking for any literature i.e. repair manual stuff for this P&H.It welds great but the hi freq doesn't work. Any help would be appreciated.Thanks Matt email:[email protected]
Reply:Do you have any specs on the mica capacitor?  I might have one if I knew what capacitance and voltage rating you need.  In the old days, mica capacitors hada series of colored ***s on them.  This is the "color code" that tells you the value of the capacitor in mfd microfarads) or pf (picofarads) and the tolerance.  If you find a color code, describe it to us.Newer mica capacitors have the values printed on the body in plain text.awright
Reply:If Miller doesn't stock it and you know the specs, check out digikey or jameco. For components they're both good sources, and cheap to boot.
Reply:Thanks for the help guys.I found a capacitor, but it didn't fix the problem.Oh well back to board.Thanks again matt
GMT+8, 2025-12-28 11:55 , Processed in 0.102643 second(s), 18 queries .
