Procon 1300 series TIG cooler pump
发表于 2021-8-31 23:04:28 | 显示全部楼层 |阅读模式
Well fellow welders , I feel pretty dump right now....... I took the screen out to clean it, wife called and I don't recall if it's suposed to seat all the way to the bottom of the pump housing.. There are rings top and bottom on the screen itself and it seems I would need to force it down to bottom out in the screen receiver area .......... The cap fits over the screen without issue .  Is the screen supposed to be flush with the top of the housing before the nut is applied??? Here is a li9nk to the pump but it does not show a clear pic.Thanks Altec http://www.piecesml.com/english/en-p...tric_icon.html
Reply:Drop the screen into the cap and insert into the pump. There is not much anywhere else for it to go.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-28 11:56 , Processed in 0.071539 second(s), 18 queries .
