new torch tip question
发表于 2021-8-31 23:04:27 | 显示全部楼层 |阅读模式
Hello,I have recently bought an older used Craftsman torch set (gauges, hose, and torch with tips).  I am assuming that it is set up for Oxy/Acet, but I want to use it with propane so I'm going to change the tip.  Problem is that I can't find a "Craftsman" tip.... I think the tip is a Harris style but thought I'd post a picture and see if any one could confirm this.I've found a Harris, Ox/Prop tip here.   Wonder if it would work?Thanks
Reply:Sorry about the big picture... tried to edit but did not see how.. here is a smaller image
GMT+8, 2025-12-28 11:55 , Processed in 0.073101 second(s), 18 queries .
