查看: 13|回复: 0
Good deal on Lincoln175hd?
发表于 2021-8-31 23:04:25 | 显示全部楼层 |阅读模式
I stopped at this pawn shop which I never do and  I see a brand new Lincoln 175 hd with all the fittings the spools were still in the wrapper and the clamp didn't have a scratch. They add it for 399 and I lowball end at 325$ and they took it. Good buy or not?Last edited by bigsal51; 09-26-2012 at 03:24 PM.
Reply:What do I need to weld 1/4in steel?
Reply:1/4" will push that little machine to it's max and probably slightly beyond. Lincoln only shows one option for 1/4" and that is.035 FC wire.  Even then they recommend multiple passes, so that usually means the machine is probably best if kept under 3/16" for critical welds. They don't show any recommendations for solid wire in that machine that thick.Manual for that machine if you don't have it.http://www.lincolnelectric.com/asset...ln3/imt825.pdf.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:That price is reasonable if it is almost new.  Does it have the regulator?Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Its equivelent to the 180HD that Home depot now sells if you want a price comparison.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Yea it came with everything but the tank. The machine looks like it hasn't even been plugged in
GMT+8, 2025-12-28 13:48 , Processed in 0.096471 second(s), 18 queries .
