I picked up a Solar 165 MIG welder tonight that needs a new drive motor put into it for the wire feed. Does anyone here know where I can get a replacement part. I would even buy a bad one that is in good physical condition because all that is wrong is the guy before me broke off one of the threaded little tubes that holds a brush inside the motor for it to operate. It has 4 brushes for it so I figure it is either reversible or 2 speeds which is more likely. I attached a few photos of the motor. On the one side of it you can see where he broke off the threaded tube where the brush is inserted and a plastic threaded cap holds it into the armature.If I can even get a burnt out one I can use the body from it and brushes to fix this one. Attached Images
Reply:Pics are bad. Do you have he part he broke off?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Solar 165 for parts: http://akroncanton.craigslist.org/tad/3268254519.html"USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Yes I have the old parts I found inside it today and also the link is the one I have that was on Craigs List. That ad is this one we are discussing. Going to get a brush at a motor repair shop and epoxy the plastic threads back onto it then see what gives.. I know it runs fine by putting a wire into the brush hole for contact. Brushes are about 1/8 " square and the wire and spring on them are about 3/4 " long or so.
Reply:If you go to a Machine shop and give them one of the other tubes they could probably turn something for you. It shouldn't take long or be expensive. A piece of nylon rod with the appropiate tap... and you are good to go. I wouldn't try to glue anything to it. At bests you will only be able to use that motor for as long as the brush lasts... Then you will have a hell of a time taking all that glue appart to replace the brush.Mikel |
