Finishing
发表于 2021-8-31 23:04:13 | 显示全部楼层 |阅读模式
Not sure where to post this, but I'm trying to duplicate a finish I've seen on some custom built furniture.  They create a black and a rust finish depending on your request.  The rust is very subtle and smooth, just a hint of orange color.  It looks really good.  They of course won't give me the exact chemical they use but maybe you can figure it out from their description:The chemical is a non-toxic steel penetrator that is similar to whatthey use for gun finishes. It penetrates the steel, sealing it andpreventing it from further rusting. When we first apply it, it turns thesteel black immediately. If we leave it on for a longer period of time,it starts a rusting process which is stopped once the chemical is washedoff with water.After that, once the it dries, we then seal it with several coats of alow-gloss clear-coat.Any ideas?
Reply:OK here is the everything I could think of off the top of my head.1 JAX Iron black (or one of there other products) 2 one of the Brownell's products (plum brown comes to mind) 3 ferric chloride 4 hydrogen peroxide5 one of the cold gun blueing products (44-40, dictopan etc.)MPHeat it and Beat it!!!http:www.Fallinghammerproductions.com
GMT+8, 2025-12-28 13:48 , Processed in 0.099466 second(s), 18 queries .
