Welding Overflow Radiator Tank For 63 'Vette
发表于 2021-8-31 23:04:06 | 显示全部楼层 |阅读模式
I have to weld a new fitting on the above.  Would you use 4043 or 5356 filler?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:4043.High temps can cause intergranular corrosion with 5356 .Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Thanks.  I knew about the heat thing and 5356, I just wasn't sure at what temp it became an issue.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Anyone have a clue what the base aluminum alloy was that GM used on these?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-28 11:54 , Processed in 0.071767 second(s), 18 queries .
