How do I make better welds?
发表于 2021-8-31 23:04:02 | 显示全部楼层 |阅读模式
i finally got my lincoln 175hd to work. but the welds are fat and tall. what can i do to make them better. i started right top to left then right to left bottom. the two on the top sides are from my 225 ac with a 6011 at the highest settings and it was hot. settings for 175hd.035 wire75/25 gas1/4in platespeet 7.5E heat
Reply:Is the polarity right ? Also clean your steel to fresh shiney metal350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Your weld will wet out WAY better on clean metal.
Reply:Yea the polarity is correct. The lincoln repair guy set it up for me. I wanted to see if I could weld in rusty metal and it did penetrate plenty. It was bright red underneath after the weld I think I was going to slow too. So what should the gas setting be set on?
Reply:15cfh is about right.
Reply:I guess the polarity was wrong. I figured he set it upright.
GMT+8, 2025-12-28 11:54 , Processed in 0.163509 second(s), 18 queries .
