What breaker should I have for my Lincoln ac225
发表于 2021-8-31 23:04:02 | 显示全部楼层 |阅读模式
I have been having some issues with my welder not penetrating enough on 1/4" steel. So I started looking at changing leads and going through making sure I have good contact. I also did a lot of grinding on the steel but still same results. I'm using a Hobart probe 6013 and tryed 6011 and the 6011 I can't keep arc but the 6013 is having trouble staying arc. So I checked the breaker and I saw I had a 20amp 120/240 breaker is this enough?
Reply:To get full output (225 amps) from the Lincoln AC225 you require a 50amp breaker.  For normal welding with say 1/8 inch electrodes I'd say you need at least a 30 amp breaker - better with a 40.  Read the manual; if you don't have one - download it from the Lincoln site.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Like Rick said, a 50 for decent output.  I tried mine on a 30, got around 6 seconds of weld at 125 amps before the breaker blew.  You rod troubles should have nothing to do with your breaker.  If your not blowing the breaker, the machine is receiving enough juice to do what you set it to.  Sounds like youre not using enough amps.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:20 amps on an AC 225 is too low unless you are running at the very bottom of the amp range. a 30 amp breaker will do 3/32" rods, but you will trip with most 1/8" rods when you crank the amps up high enough for that size rod. as said a 50 amp is enough to run anything you need with that machine and is the recommended size.Post up what amp setting and rod size you are trying to run. My guess is your amps are too low and your rod size is too large because you aren't tripping your small breaker..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Dont forget you need the right size wire too. The breaker is there to protect the wire from starting a fire.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by dumb as a stumpDont forget you need the right size wire too. The breaker is there to protect the wire from starting a fire.
Reply:Information, if the breaker is not blowing then the machine is working.  If the machine is working then at the 120 amps he needs for 1/8 on quarter should not be a problem.  If your fan is running then the machine is not overloaded,  check your ground and stinger leads, make sure all have good contact witn the power cables.  Make sure you are grounded and try welding as close to the ground as possible. Also make sure your input is hot at both terminals at the mach., 110 between black and green, 110 between white and green.
Reply:Found the issue just wondering what it was that did it
Reply:hmmm looks like you may have melted the wires then it shorted out when the exposed wire contacted the grounded box... who knows thoESAB Heliarc 252
Reply:From the looks of the cob web and what appears like a melted  tab at the screw the wire coating fatigued and shorted out like the man just said.
Reply:The best breaker, if it is at all possible, is your neighbours breaker so that it is his electric bill as well.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
GMT+8, 2025-12-28 12:04 , Processed in 0.097511 second(s), 18 queries .
