Gas with FCAW-S?
发表于 2021-8-31 23:04:01 | 显示全部楼层 |阅读模式
I know this question gets asked here periodically. Cool answer from Lincolns facebook page.Q: I have a small MIG welder, which I sometimes use to weld with 0.045” Innershield® NR-212 wire.  I know it is a gasless wire.  However, is it okay to use shielding gas (e.g. 75%Ar / 25%CO2) with it?  I tried it once on some scrap plate and it seemed to work pretty well.  I also noticed the AWS number for the wire, E71TG-G, has the “G” in it.  Does that mean it is okay to use with gas?A:  The answer to your first question is no.  Not only is the use of any type of shielding gas not necessary for Innershield® NR-212, or any other type of self-shielded, flux-cored electrode (FCAW-S), it should not be used.  FCAW-S (i.e. Innershield®) electrodes have a tightly controlled and unique core composition and interaction with the atmosphere (compared to gas-shielded, flux-cored wires).  They rely on the oxidizing effect of air to produce the desired weld deposit and desired resulting mechanical properties.  When you use a shielding gas, you block the arc from the air and prevent the oxidizing reactions.  This results in a much higher level of alloys, such as aluminum, in the weld metal, which produces a brittle and crack sensitive weld deposit.    While it is likely that the shielding gas improves the stability and operator appeal of NR-212, it also results in an unacceptable weld deposit.Regarding your second question about the American Welding Society (AWS) classification of Innershield® NR-212 (E71TG-G), I can see where that would lead to some confusion.  While the "G" in FCAW-G stands for gas shielded (or the “S” in FCAW-S for self-shielded), the "G" in a specific electrode AWS classification stands for “general”.  Therefore, an E71TG-G classification does not mean that it is a gas-shielded electrode.  Typically, a U.S. welding electrode manufacturer (such as Lincoln Electric, etc.) designs an electrode to meet the requirements of a specific, predefined AWS electrode classification, per the appropriate AWS Filler Metal Specification (such as E71T-1, E71T-8, E7018, ER70S-6, etc.).  However, a manufacturer is still free to make a particular electrode that does not meet any predefined AWS classification.  In these cases, it is classified as "general".  Such is the case with Innershield® NR-212, in which the first "G" in the electrode’s AWS number means it has a general usability classification.  Innershield® NR-212 also happens to be a low-alloy electrode (i.e. under AWS A5.29 Filler Metal Specification).  These electrodes have alloy designations in their suffix (i.e. E71T8-K6, E81T1-K2, E81T1-Ni1, etc.).  In the case of Innershield® NR-212, the second “G” is a general alloy suffix classification.  Therefore, E71TG-G is its classification."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Cool, that answers a question I've been wondering about. Thanks!Tom
GMT+8, 2025-12-28 11:54 , Processed in 0.179770 second(s), 18 queries .
