mig spot welding question
发表于 2021-8-31 23:03:59 | 显示全部楼层 |阅读模式
i am replacing my cars radiator support and the new one needs to be spot welded. i have never welded before but i am a do it yourselfer so i wanted to rent one out and do it. how would i make spot welds and what should i know. i have been told to get a mig welder what is the difference.thanks
Reply:One way to "spot weld " a bracket with a mig, is to drill a hole in the bracket. Then place it against where you want to weld it to. Fill the hole in. May need to do several welds.In a car most of those spot welds are made with a resistance welder. A Clamp that can pass very high current ( 3000amps or more) and melt the metal together. No arc.Body shops use a spot weld drill bit,to remove the weld and leave a hole that is ready to mig weld for reassembly.Do find a friend to help, or at least teach you the basics of welding. Before you have a car that is full of holes or the radiator falls out when going down the free way.Last edited by ccawgc; 10-05-2012 at 11:27 PM.
Reply:Originally Posted by ccawgcOne way to "spot weld " a bracket with a mig, is to drill a hole in the bracket. Then place it against where you want to weld it to. Fill the hole in. May need to do several welds.In a car most of those spot welds are made with a resistance welder. A Clamp that can pass very high current ( 3000amps or more) and melt the metal together. No arc.Body shops use a spot weld drill bit,to remove the weld and leave a hole that is ready to mig weld for reassembly.Do find a friend to help, or at least teach you the basics of welding. Before you have a car that is full of holes or the radiator falls out when going down the free way.
Reply:Might wanna grab a couple of pieces of scrap (as close to the same thickness and type as you can find) and mimic the weld you are trying to do. Put the pieces in the same position (Vertical, flat, etc) that the parts in the car are oriented at. This will give you a much better idea than anyone can try to explain on a forum. And if you mess up, it's just scrap.If you've never tried to weld before, you're gonna have a few more questions than how long to hold the trigger after you strike that first arc.Last edited by Snuffy; 10-06-2012 at 03:09 AM.
Reply:Post your location.  Maybe someone can lend a hand.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Heres a good video also Google spot or plug weld with mig plenty of stuff out there http://www.google.com/url?sa=t&sourc...GYnTSjlaFn7TaQ350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-28 13:48 , Processed in 0.070483 second(s), 18 queries .
